Competition for Single Carbon Source Between Denitrification and Phosphorus Release in Sludge under Anoxic Condition
| 论文类型 | 技术与工程 | 发表日期 | 2010-03-01 |
| 来源 | BIOTECHNOLOGY AND BIOENGINEERING | ||
| 作者 | PENG,Zhaoxu,(彭赵旭),,PENG,Yongzh | ||
| 关键词 | denitrification, SBR, phosphorus release, pH, organic substrate | ||
| 摘要 | In order to investigate the competition for carbon source between denitrification and phosphorus releaseprocesses,simultaneous phosphorus release and denitrification in sludge operated in anoxic, aerobic mode are investigated by varying the ratio of influ | ||
相关推荐
- 初始底物浓度及pH对丁酸梭菌T4发酵木糖产氢的影响
- Competition for Single Carbon Source Between Denitrification and Phosphorus Release in Sludge under Anoxic Condition
- Enhanced Biological Nutrients Removal in Modified Step-feed Anaerobic/Anoxic/Oxic Process
- The effect of aerating to sediment on phosphorus adsorption capacity and phosphorus forms in the sediment
- Micro-Polluted Surface Water Treatment by PAC-MBR Process
- Cr_3_改性膨润土用于处理特定有机废水的实验研究(英文)
