Arsenic(V)removal with a Ce(IV)-doped iron oxide adsorbent
| 论文类型 | 技术与工程 | 发表日期 | 2006-03-01 |
| 作者 | Yu,Zhang,杨敏,Xia,Huan | ||
| 关键词 | Arsenic removal Adsorption Groundwater Iron oxide Cerium | ||
| 摘要 | The removal of arsenic(V) by a new Ce–Fe adsorbent was evaluated under various conditions. Under an initial As(V) of 1.0 mg l-1, the adsorption capacity of the Ce–Fe absorbent was constant around a value of 16 mg g-1 over a wide pH range (3–7), while a ma | ||
相关推荐
- 枣椰仁颗粒活性碳及其在多介质过滤器中余氯穿透曲线动态建模(英文)
- Nitrifying Population Optimization in Municipal Saline Wastewater Treatment
- Separation of Sulfur/Gasoline Mixture with Polydimethylsiloxane/Polyetherimide Composite Membranes by Pervaporation
- Enhanced Biological Nutrients Removal in Modified Step-feed Anaerobic/Anoxic/Oxic Process
- The effect of aerating to sediment on phosphorus adsorption capacity and phosphorus forms in the sediment
- Characterization of the start-up period of single-step autotrophic nitrogen removal in a sequencing batch reactor
