MSBR techniques
| 论文类型 | 技术与工程 | 发表日期 | 2006-01-01 |
| 作者 | 佚名 | ||
| 关键词 | MSBR techniques | ||
| 摘要 | MSBR techniques MSBR is Modified Sequencing Batch Reactor,which is more ideal sewage disposal techniques developing based on SBR techniques,combining traditional active mud technology.MSBR don‘t | ||
MSBR techniques
    MSBR is Modified Sequencing Batch Reactor,which                 is more ideal sewage disposal techniques developing  based on SBR                 techniques,combining traditional active mud technology.MSBR don‘t                 need primary and secondary depositing pools,but can continuously                 feed water or draining with stable water line.The single pool with                 multiple grids need no connecting pipelines,pumps and valves.Besides,the                 continuously draining can take full use of the pool and equipments.MSBR                 techniques are applied for various sewage disposal and municiple                 sewage.
1.Single pool with multiple grids.The SBR unit                 works as sequencing batch reactor and depositing pool in the whole                 circulation to guarantee the continuously draining.
                2.Install low lift wall crossing circumfluence pump to increase                 MLSS in SBR,reduce the thickness of mud of SBR so that the left                 mud contains more solid(>2%),and reduce energy spending without                 the mud concreting processing unit.
                3.To add hypoxia unit,the denitrifying function is higher and energy                 spending and mud production are less.
                4.It feeds water from the bottom of SBR and the sewage has antinitrification                 and endogenous respiration,so the performance of mud is more stable.The                 mud plays the role of filtering and the water quality is better.
                5.Full automatic controlling
                6.Good effect of denitrification and dephosphorization needing no                 medicine.
                7.Occupying less area,low operation cost.
SBR applying for the following fields
MSBR techniques can dispose industrial sewage(beer, butcher, food,coking,printing and dyeing),municiple sewage,especially the denitrification and dephosphorization of municiple sewage.
Developed by: Beijing Heroka Environmental Engineering Technology Co., Ltd.
close
www.h2o-china.com论文搜索
