Treatment of Municipal Wastewater with Biological/Chemical(B
| 论文类型 | 技术与工程 | 发表日期 | 2006-01-01 |
| 作者 | ZHOU,Ke,zhao | ||
| 关键词 | wastewater treatment activated sludge chemical flocculation chemical phosphorous removal | ||
| 摘要 | BC process is a wastewater treatment process combined biological treatment (high rate activated sludge) with chemical treatment (chemical flocculation and phosphorous removal). The marked feature of this process is the addition of chemical flocculant (fer | ||
相关推荐
- Effects of Slow-Mixing on the Coagulation Performance of Polyaluminum Chloride (PACI)
- 枣椰仁颗粒活性碳及其在多介质过滤器中余氯穿透曲线动态建模(英文)
- Nitrifying Population Optimization in Municipal Saline Wastewater Treatment
- Separation of Sulfur/Gasoline Mixture with Polydimethylsiloxane/Polyetherimide Composite Membranes by Pervaporation
- Enhanced Biological Nutrients Removal in Modified Step-feed Anaerobic/Anoxic/Oxic Process
- Characterization of the start-up period of single-step autotrophic nitrogen removal in a sequencing batch reactor
